Digital Inputs with 2.2K ohm resistor - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-AI (https://www.kincony.com/forum/forumdisplay.php?fid=29) +--- Thread: Digital Inputs with 2.2K ohm resistor (/showthread.php?tid=5658) |
Digital Inputs with 2.2K ohm resistor - bruces - 04-28-2024 So I need to know if i were to connect a DI to ground through a 2200 ohm resistor would the input trip. I am trying to replace an old security system and all of the inputs have two states, open circuit or 2200 ohm in the line. I would just remove the 2200 ohm resistor but most of them are not accessible. RE: Digital Inputs with 2.2K ohm resistor - admin - 04-28-2024 what voltage you want conenct with digital input port? DC24V? RE: Digital Inputs with 2.2K ohm resistor - bruces - 04-29-2024 12 Vdc RE: Digital Inputs with 2.2K ohm resistor - admin - 04-29-2024 if you want KC868-AI's board work with 12v signal by digital input port. just directly to use it. Not need replace the resistance. |
