Tuya app response - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: Tuya app response (/showthread.php?tid=5774) |
Tuya app response - Saif Kitany - 05-20-2024 I noticed that controlling my H32B by kincony smart home app, the response is quicker more than by tuya app. Why is that??? 1 my H32B connected to router by ethernet cable, and the configuration in H32B is set as “UDP” 2.the tuya adapter configured as tcp connection. RE: Tuya app response - admin - 05-20-2024 when use tuya adapter by "TCP Connection", set H32B ethernet work mode = TCP Server. RE: Tuya app response - Saif Kitany - 05-20-2024 Will correct myself: Ethernet work mode= TCP Server Wifi work mode = UDP In this case i can use kincony smart home app and tuya app in the same time. And i noticed that the response when i turn on any relay from kincony smart home app is quicker than tuya app. Why is that? RE: Tuya app response - admin - 05-20-2024 test set wifi work mode = TCP Server too. just use only Tuya app. |
