power input 24v - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: power input 24v (/showthread.php?tid=5785) |
power input 24v - tech1977 - 05-22-2024 Is it possible to use 24v for power input instead of 12v? RE: power input 24v - admin - 05-22-2024 no, A32 only use dc12v power supply, because relay coin is dc12v version. RE: power input 24v - tech1977 - 05-23-2024 (05-22-2024, 10:04 PM)admin Wrote: no, A32 only use dc12v power supply, because relay coin is dc12v version.but here I asked for KC868-A16 .... RE: power input 24v - admin - 05-23-2024 A16 support DC12-24V for power supply. RE: power input 24v - djbeuk - 07-10-2024 Hi. I just ordered an A16 as well and I had the same question. The image shows 12/24V for the DC Input for the digital outputs. But only 12V for Power Input. So just to confirm - the Power Input for the board itself can also be 24, correct? ![]() Thanks in advance. RE: power input 24v - admin - 07-10-2024 yes, you are right. you can use DC12v for all terminal or DC24v for all terminal (include power input port). RE: power input 24v - korl - 02-03-2026 (07-10-2024, 09:50 PM)admin Wrote: yes, you are right. you can use DC12v for all terminal or DC24v for all terminal (include power input port). Is it possible to 1. supply the A16 with 12 V and power one Terminal with 12 V and the other Terminal with 24 V? 2. supply the A16 with 24 V and power one Terminal with 12 V and the other Terminal with 24 V? I would like to connect different devices, some use 12 V, some use 24 V RE: power input 24v - admin - 02-03-2026 both ok, just two power supply GROUND should connect together. |
