ESPHome DAC output DC 0-10V - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8M (https://www.kincony.com/forum/forumdisplay.php?fid=48) +--- Thread: ESPHome DAC output DC 0-10V (/showthread.php?tid=6012) |
ESPHome DAC output DC 0-10V - marek - 07-02-2024 Is it possible to use outputs V-OUT1-8 to control a car charger that requires a control DAC output DC 0-10V? If possible, I would need a KC868-A8M ESP32 I/O pin define. I assume that the next work will be similar to the post for KC868-AP / ADR: https://www.kincony.com/forum/showthread.php?tid=2889 RE: ESPHome DAC output DC 0-10V - admin - 07-02-2024 KC868-A8M is mosfet output, not use for 0-10v output. if you want use 0-10V output, you can use KC868-A4S or other model. here is ESP32 IO pin define for KC868-A8M: https://www.kincony.com/forum/showthread.php?tid=2790 |
