attach door sensor to the server - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-Server Raspberry Pi4 local server (https://www.kincony.com/forum/forumdisplay.php?fid=17) +--- Thread: attach door sensor to the server (/showthread.php?tid=6039) |
attach door sensor to the server - sheheryar - 07-09-2024 hello admin, i attached the door sensor as the wiring in the photo and also did the programming as given in the picture still there is no response in home assistant RE: attach door sensor to the server - admin - 07-09-2024 check here: https://www.kincony.com/mqtt-input-module-home-assistant.html there have yaml file link, compare with your mqtt syntax. RE: attach door sensor to the server - sheheryar - 07-10-2024 solved thank you RE: attach door sensor to the server - admin - 07-10-2024 ok, good. |
