KinCony ALR ESP32-S3 LoRa SX1278 Gateway released - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KinCony ALR ESP32-S3 LoRa SX1278 Gateway released (/showthread.php?tid=6167) |
KinCony ALR ESP32-S3 LoRa SX1278 Gateway released - admin - 07-21-2024 We have designed ESP32 LoRa SX1278 Gateway - KinCony ALR. It support install into waterproof box. it use ESP32-S3-WROOM-1U N16R8 chip. small PCB with relay,SSD1306 LCD, 4 channel analog input, digital input, i2c bus extender, 1-wire GPIO, SX1278 LoRa module, DIP switch set for LoRa address.It can use for smart home IoT project use by home assistant. ESP32-S3 also support arduino IDE / MicroPython / ESP-IDF development tool. ![]() ![]() Hardware resource: Power supply: DC9-24V USB-C: download firmware Buttons: ESP32 Reset and Download ESP32-S3-WROOM-1U N16R8 SX1278 LoRa module Relay: MAX Load AC250v10A COM,NO,NC SSD1306 i2c LCD 8bit DIP switch: set LoRa device address Analog Input: 4 channel dc 0-5v signal 1-wire: 1 channel digital input: 1 channel (dry contact signal) I2C bus: 1 RE: KinCony ALR ESP32-S3 LoRa SX1278 Gateway released - markbrewer - 01-30-2025 Hi, how many slaves can be connected to one gateway? RE: KinCony ALR ESP32-S3 LoRa SX1278 Gateway released - admin - 01-31-2025 if you can write your own arduino code , it's no limit. just according to your software code. RE: KinCony ALR ESP32-S3 LoRa SX1278 Gateway released - markbrewer - 01-31-2025 I would like to use it with home assistant and NOT have to develop any code. Would the Home Assistant be able to discover all the devices connected to it? RE: KinCony ALR ESP32-S3 LoRa SX1278 Gateway released - admin - 01-31-2025 if you using our firmware, it's just a demo, only one "slave" board. RE: KinCony ALR ESP32-S3 LoRa SX1278 Gateway released - markbrewer - 02-05-2025 Will you be modifying your firmware to cater for multiple slave boards in the future? RE: KinCony ALR ESP32-S3 LoRa SX1278 Gateway released - admin - 02-05-2025 you can modify arduino source code by yourself? if OK, we send code to you. |
