DHT22 with A32PRO - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A32/A32 Pro (https://www.kincony.com/forum/forumdisplay.php?fid=27) +--- Thread: DHT22 with A32PRO (/showthread.php?tid=6512) |
DHT22 with A32PRO - Marcin - 08-28-2024 I am trying to connect DHT22 to A32PRO. I connected three DHT22 pins in the following way: data pin -> W1 VCC -> 3V3 GND -> GND There is 10kOm pull up resistor between 3V3 and W1 installed. This is how I configure DHT22 in ESPHOME: sensor: - platform: dht pin: GPIO1 model: DHT22 temperature: name: "Temperature" humidity: name: "Humidity" update_interval: 10s The status in Home Assistant is "unknown". What am I doing wrong? Did I connected and configured correctly? Thank you for explanation in advance. RE: DHT22 with A32PRO - admin - 08-28-2024 please upload your photo , how you wire. i can't see your photo. RE: DHT22 with A32PRO - Marcin - 08-29-2024 (08-28-2024, 10:29 PM)admin Wrote: please upload your photo , how you wire. i can't see your photo. RE: DHT22 with A32PRO - admin - 08-29-2024 do you have added the extend 10k resistance by yourself? if YES, remove it, our pcb already have the pull-up resistance for 1-wire pin. RE: DHT22 with A32PRO - Marcin - 08-29-2024 (08-29-2024, 08:50 AM)admin Wrote: do you have added the extend 10k resistance by yourself? if YES, remove it, our pcb already have the pull-up resistance for 1-wire pin. You are right. It works fine without additional resistor. Thank you fo your help. RE: DHT22 with A32PRO - admin - 08-29-2024 you are welcome. |
