KC868-A8 Ethernet Problem - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: KC868-A8 Ethernet Problem (/showthread.php?tid=6809) |
KC868-A8 Ethernet Problem - Namil Heo - 09-30-2024 Hello, i have a KC868-A8 Board connected with ethernet cable but the port suddenly stopped working. # define ETH_ADDR 0 #define ETH_POWER_PIN -1 #define ETH_MDC_PIN 23 #define ETH_MDIO_PIN 18 #define ETH_TYPE ETH_PHY_LAN8720 #define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT IPAddress local_ip(192, 168, 0, 144); IPAddress gateway(192, 168, 0, 254); IPAddress subnet(255, 255, 255, 0); ETH.begin(ETH_TYPE, ETH_ADDR, ETH_MDC_PIN, ETH_MDIO_PIN, ETH_POWER_PIN, ETH_CLK_MODE); if (ETH.config(local_ip, gateway, subnet, dns, dns) == false) { Serial.println("EtherNet failed."); }else{Serial.println("EtherNet Success.");} Serial.println("Connected"); Serial.print("IP Address:"); Serial.println(ETH.localIP()); delay(500); |
