KinCony F16 ESP32-S3 16A Removable Relay Board released - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KinCony F16 ESP32-S3 16A Removable Relay Board released (/showthread.php?tid=6838) |
KinCony F16 ESP32-S3 16A Removable Relay Board released - admin - 10-05-2024 KinCony F16 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 16 manual control switch buttons can turn ON/OFF relay even if system is broken. 16 channel removable OMRON high-quality relay, 4 channel 1-wire GPIOs, 2 free GPIOs, 4 channel analog input ports. One SD card using SPI bus. KinCony F16 include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. F16 have RS485 port and RF433MHz RF receiver. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. ![]() Model No. KinCony F16 Description: KinCony 16 Channel ESP32-S3 Removable Relay Controller – F16 Power supply: 12/24V DC (Default install by 12V OMRON relay) Processor: ESP32-S3-WROOM-1U (N16R8) Size: 262mm*127mm*62mm interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C,LCD,Tuya Module RTC: DS3231 high precision chip (battery socket on PCB) SD Card: SPI bus Installation method: DIN RAIL LCD: SSD1306 I2C display Outputs: 16CH OMRON removable relay, every channel have "COM"(common) and "NO"(normal open) ports. MAX load 250VAC/16A 30VDC/16A Inputs: 2CH analog input DC0-5V (A1,A2) 2CH analog input 4-20mA (A3,A4) 16CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable) 3 buttons: 1:ESP32 Reset 2:ESP32 Download 3:Tuya config 1-Wire GPIO: 4CH (with pull-up resistance on PCB) free GPIO: 2CH (without pull-up resistance on PCB, connect with ESP32 pin directly) RF receiver socket: 433MHz RF receiver ![]() software solution: 1. download firmware by ESPHome, integrate to home assistant or use by web service. 2. download tasmota firmware. 3. write your own arudino code for your own requirements. 4. It is recommended to use home assistant and Tuya mobile phone app at the same time. So that remote control by internet using Tuya app, local control by LAN using home assistant app. Related technical information ——————————— ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=6814 config yaml file for ESPHome: https://www.kincony.com/forum/showthread.php?tid=6815 arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=63 Different views of the F16: ![]()
