Server 16 Raspberry Specs - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module (https://www.kincony.com/forum/forumdisplay.php?fid=53) +--- Thread: Server 16 Raspberry Specs (/showthread.php?tid=6873) |
Server 16 Raspberry Specs - LandOfMosfet - 10-14-2024 I have trouble finding the specifications for this unit. Just basic stuff like: What is the DC voltage and current requirements? Voltage rating for digital input I have the unit in front of me but before I get started I would like to have all the Thanks! RE: Server 16 Raspberry Specs - admin - 10-14-2024 Power supply: DC12V 2.5A Digital input: 16CH with optocoupler isolation cable MAX: 500 meter dry contact signal if want connect input voltage: logic "1": input DC0V logic "0": input DC12V free GPIOs from CM4 pins: GPIO16 GPIO17 GPIO20 GPIO21 GPIO22 GPIO23 GPIO24 GPIO25 here are CM4 hardware resource: https://www.kincony.com/forum/showthread.php?tid=5418 Do you want use install home assistant? RE: Server 16 Raspberry Specs - LandOfMosfet - 10-17-2024 Thanks! I will try a few different things. Probably start with NodeRed. RE: Server 16 Raspberry Specs - admin - 10-17-2024 Yes, Node red is easy, we have supply sample node, you can download from our forum. |
