USB-C Connectivity and COM Port Issue with KC868-A4S Relay Controller - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: USB-C Connectivity and COM Port Issue with KC868-A4S Relay Controller (/showthread.php?tid=7094) |
USB-C Connectivity and COM Port Issue with KC868-A4S Relay Controller - Bhumijo - 11-20-2024 Hello, I am facing an issue with my KC868-A4S relay controller. When I connect the device to a PC via a USB-C cable, the PC does not recognize it. The red light on the device turns on when powered, but there’s no indication that the USB-C connection is active, and the COM port does not appear. Here are the steps I’ve tried so far:
Could you please guide me on how to resolve this issue? Additionally, if the device itself is not working, is there a way to verify whether the hardware is functioning correctly or an alternative method to test it? Looking forward to your suggestions. Thank you! RE: USB-C Connectivity and COM Port Issue with KC868-A4S Relay Controller - admin - 11-20-2024 USB-C cable whether connect to computer directly? not by USB-HUB? i suggest you use another computer for a testing. RE: USB-C Connectivity and COM Port Issue with KC868-A4S Relay Controller - Bhumijo - 11-20-2024 (11-20-2024, 11:38 AM)Bhumijo Wrote: Hello, RE: USB-C Connectivity and COM Port Issue with KC868-A4S Relay Controller - Bhumijo - 11-20-2024 tried with another pc, connect to the pc directly with that data cable, RE: USB-C Connectivity and COM Port Issue with KC868-A4S Relay Controller - admin - 11-20-2024 contact with whatsapp number: +86-15381188302 we use ANYDESK remote control your PC to have a look. |
