KinCony TS Tiny SHT30 Temperature And Humidity Sensor released - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KinCony TS Tiny SHT30 Temperature And Humidity Sensor released (/showthread.php?tid=7573) |
KinCony TS Tiny SHT30 Temperature And Humidity Sensor released - admin - 02-07-2025 KinCony TS (Tiny Sensor) made by SHT30 temperature and humidity sensor inside. ![]() ![]() product size: 20mm*18mm power supply: DC 9-36V temperature: -40℃-- +125℃ humidity: 0--100% RH temperature accuracy: 0.1℃ humidity accuracy: 0.1% RH communication: RS485 RS485 baud rate: 9600/14400/19200/38400/56000/57600/115200 bps RS485 address: 1--255 editable LED D3: power LED LED D4: running LED (blink with running) Jumper: RS485 Terminating resistor jumper (make sure last RS485 slave device enable it) ![]() You can read temperature and humidity by PC software via RS485 USB adapter. you can set KinCony TS by different address and Baud. ![]()
RE: KinCony TS Tiny SHT30 Temperature And Humidity Sensor released - Yocee - 06-13-2025 What is the difference this, and boxed ( https://shop.kincony.com/products/rs485-temperature-and-humidity-sensor-modbus-rtu-use-by-sht30 ) sensor? Price is 5x. RE: KinCony TS Tiny SHT30 Temperature And Humidity Sensor released - admin - 06-15-2025 make the sensor smaller , cost will be high. it's 4 layer PCB version, more stable. |
