hello, i have a question about the relay board - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: hello, i have a question about the relay board (/showthread.php?tid=7588) Pages:
1
2
hello, i have a question about the relay board - wkdrlfska - 02-08-2025 I watched YouTube and connected the relay controller to the app. But when I press the switch on the app, there is no relay operation sound and the LED light does not turn on. My board is old 8CH. Please help me RE: hello, i have a question about the relay board - admin - 02-09-2025 take a photo which controller you are using. please write your question in details. RE: hello, i have a question about the relay board - wkdrlfska - 02-09-2025 (02-09-2025, 02:43 AM)admin Wrote: take a photo which controller you are using. I have two controllers, H8B and H8W, I watched kincony youtube to do the test. I connected it to the app, but there's no LED light and relay operation sound. There was a reaction in the datalog when I pressed the switch, so I checked it and it seems to be a normal response. RE: hello, i have a question about the relay board - admin - 02-09-2025 kincony cloud server stop use in 2024-12-31 https://www.kincony.com/forum/showthread.php?tid=5437 kincony smart home app is stop to use. the PC software or KBOX software also can work in locally. RE: hello, i have a question about the relay board - wkdrlfska - 02-09-2025 (02-09-2025, 07:16 AM)admin Wrote: kincony cloud server stop use in 2024-12-31 We used the tuya app and also used ESP32 Tuya IoT Adapter V2 RE: hello, i have a question about the relay board - admin - 02-09-2025 ok, if you use by tuya adapter v2, just do as this video: https://youtu.be/zSOtzTXvUiI make sure you have set the network mode = TCP Server using Vircom tool. RE: hello, i have a question about the relay board - admin - 02-09-2025 https://www.kincony.com/download/VirCom_5.33.zip RE: hello, i have a question about the relay board - wkdrlfska - 02-09-2025 (02-09-2025, 12:24 PM)admin Wrote: ok, if you use by tuya adapter v2, just do as this video:i saw that! How do I set it up here? (picture) RE: hello, i have a question about the relay board - wkdrlfska - 02-09-2025 (02-09-2025, 12:43 PM)admin Wrote: https://www.kincony.com/download/VirCom_5.33.zipvery thank you How do I set it up here? (vircom) RE: hello, i have a question about the relay board - admin - 02-10-2025 yes, scan your device firstly. |
