DOA? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: DOA? (/showthread.php?tid=7715) |
DOA? - jeffer - 02-24-2025 I just received my board. The USB-C port does not respond at all, and when I connect to the network, the board has the IP address 192.168.1.200, but the only open port is 53. I have put my computer on the same subnet and scan via UDP_SCAN_LIST and nothing is found. I have tried holding both reset and download buttons (both together and at different times) and no results. RE: DOA? - admin - 02-25-2025 you need to download KCS v2 firmware by USB-C cable firstly. USB driver: https://www.kincony.com/download/CH341SER.zip KCS v2 online guide: https://www.kincony.com/esp32-kcsv2-firmware.html RE: DOA? - jeffer - 02-25-2025 (02-25-2025, 01:09 AM)admin Wrote: you need to download KCS v2 firmware by USB-C cable firstly. Fixed, thank you! |
