KC868-M30 - how to get it to work - Printable Version
+--- Forum: KC868-M16 / M1 / MB / M30 (https://www.kincony.com/forum/forumdisplay.php?fid=50)
+--- Thread: KC868-M30 - how to get it to work (/showthread.php?tid=7742)
KC868-M30 - how to get it to work - msmrz - 02-28-2025
I just received the M30. And I don't know how to get it to work. I haven't found any documentation or user guide for the M30.
My scenario is to configure the M30 to provide measured data via MQTT to other systems.
I want to connect to M30 and configure it. But it looks like the ethernet connection is not working.
If I connect the M30 to the switch, LED on the ethernet port doesn't blink.
RE: KC868-M30 - how to get it to work - admin - 03-01-2025
you need to download KCS firmware firstly.
https://www.kincony.com/forum/showthread.php?tid=6760
RE: KC868-M30 - how to get it to work - msmrz - 03-03-2025
Thank you for your answer and advice.
I finally managed to get it working.
It would be nice to provide some step by step user guide.
What I did, what is good to know:
  • I uploaded the new KCS firmware to the M30/ESP32.
  • I connected to the M30/ESP32 via wifi as it is in AP mode.
  • Is it possible to connect to the M30/ESP32 via ethernet? What is the configuration of the ethernet interface - DHCP/static?
  • Default admin login
I have some additional questions:
  • What is the sampling frequency of the individual voltage and current measurements?
  • How many measurements are done per voltage or current sine wave?
  • What is the measurement frequency of each individual input?
  • How is the active power of the individual inputs calculated? From the instantaneous voltage and current values or from the effective values?
  • How often are the measured and calculated values provided by MQTT?
RE: KC868-M30 - how to get it to work - admin - 03-03-2025
sure, you can connect with ethernet cable, it will use by DHCP mode. then use kincony scan device tool , you will find the ethernet IP address for M30.
all current and voltage channel work with 50hz or 60hz power. all calculate work manager by BL0910 energy IOT chip. just the data is different , it will auto update to MQTT topic.
RE: KC868-M30 - how to get it to work - msmrz - 03-07-2025
Thank you for your reply.
I understand that I can find details about voltage and current measurements in the documentation for the BL0910 chip.
After a week of operation, the functioning of the M30 looks quite good. No problems appeared.
