Querry regarding KC868-A16 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Querry regarding KC868-A16 (/showthread.php?tid=7744) |
Querry regarding KC868-A16 - azharrr009 - 03-01-2025 Hello! I hope you will be fine. I bought 4 KC868-A16 for trial purpose for my company. If suitable we will buy more But I am not able to program it until now. So I was thinking Kindly Can I get your WhatsApp so that any of your technical support Staff can guide me how to program KC868-A16 with Arduino IDE software. I had connected the power and ethernet port with my laptop for programming. Also I had selected the board as Nodemcu32s and selected the right port. When I start uploading the your demo code, I don't why the program doesn't upload and give me the following error; "Sketch uses 316512 bytes (24%) of program storage space. Maximum is 1310720 bytes. Global variables use 21008 bytes (6%) of dynamic memory, leaving 306672 bytes for local variables. Maximum is 327680 bytes. esptool.py v4.8.1 Serial port COM5 A serial exception error occurred: Cannot configure port, something went wrong. Original message: PermissionError(13, 'A device attached to the system is not functioning.', None, 31) Note: This error originates from pySerial. It is likely not a problem with esptool, but with the hardware connection or drivers. For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html Failed uploading: uploading error: exit status 1" Could you identify what I am doing.ad connected the power and ethernet port with my laptop for programming. Also I had selected the board as Nodemcu32s and selected the right port but I don't why the program doesn' I will appreciate your help in this regard. Thankyou, Muhammad Azhar Uddin Lead Engineer Taqueen Innovation Company, KSA +966582841063 RE: Querry regarding KC868-A16 - admin - 03-01-2025 1. Do you have installed RF receiver module on PCB, you can take a look, if installed, just remove it when download firmware. 2. take a error screen photo. RE: Querry regarding KC868-A16 - azharrr009 - 03-01-2025 (03-01-2025, 11:30 AM)admin Wrote: 1. Do you have installed RF receiver module on PCB, you can take a look, if installed, just remove it when download firmware. No, I didn't installed it the eror image is attached. Thankyou for your response RE: Querry regarding KC868-A16 - admin - 03-02-2025 check your windows "device manager" whether can find COM port number, when you connect with USB-C cable with KC868-A16. maybe you need install USB driver firstly, here is download link: https://www.kincony.com/download/CH341SER.zip RE: Querry regarding KC868-A16 - azharrr009 - 03-02-2025 (03-02-2025, 01:13 AM)admin Wrote: check your windows "device manager" whether can find COM port number, when you connect with USB-C cable with KC868-A16. Thanks it works now! RE: Querry regarding KC868-A16 - admin - 03-02-2025 ok |
