B16M Outputs & HomeAssistant Firmware - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Getting Started with ESPHome and Home Assistant (https://www.kincony.com/forum/forumdisplay.php?fid=54) +--- Thread: B16M Outputs & HomeAssistant Firmware (/showthread.php?tid=7861) |
B16M Outputs & HomeAssistant Firmware - akat - 03-23-2025 Hi all, I've recently deployed a Kincony B16M and flashed it with the stock kincony-b16m.yaml config. I’m using the digital outputs to control HF41F relays mounted on 41F-1Z-C2-1 boards. Each relay coil is connected with a 1N4007 flyback diode across A1 and A2. Wiring is as follows:
The issue: When the B16M boots, DO1 immediately energizes the relay, even though in the WebUI the output appears OFF. Toggling DO1 via the WebUI has no effect on the relay—it remains stuck on. I’ve tried both inverted: true inverted: false in the YAML under b16m-output01, but neither changes the behavior. Here's the relevant YAML snippet: Code: switch:Thanks in advance. RE: B16M Outputs & HomeAssistant Firmware - admin - 03-23-2025 take a photo of your B16M , how to wire, you'd better take a video of your problem, send to whatsapp number: +86-15381188302 |
