ESP32S3 Chip efuse check error - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: "KCS" v3 firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=74) +--- Forum: "KCS" v3 firmware (https://www.kincony.com/forum/forumdisplay.php?fid=75) +--- Thread: ESP32S3 Chip efuse check error (/showthread.php?tid=7885) |
ESP32S3 Chip efuse check error - saymyname - 03-31-2025 Hi i just received my order with KC868-A16v3 ESP32-S3 16 channel, Im trying to install kincony firmware but dowload tool keeps giving me error: [ESP8266Loader_spi[1]][espDownloader.py][line:594][ERROR]: ESP32S3 Chip efuse check error esp_check_mac_and_efuse. Can you please help me with this? Thank you RE: ESP32S3 Chip efuse check error - admin - 03-31-2025 take a screen photo how you setting when download firmware. RE: ESP32S3 Chip efuse check error - saymyname - 04-01-2025 Hi, problem was probably in connection via USB HUB, when i disconected evertything from pc and connected device directly, software was installed without any issue. And now i can connect to IP which i can see on internal display. So for now everything seems to be OK. Thanks RE: ESP32S3 Chip efuse check error - admin - 04-01-2025 ok, good. RE: ESP32S3 Chip efuse check error - shawn@itcharleston.com - 05-05-2025 Similar problem here but it was the USB-C extension RE: ESP32S3 Chip efuse check error - admin - 05-06-2025 usually need chose a high quality USB-C cable, connect to computer USB port directly. |
