BM16 Problems - Printable Version
+-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=60)
+--- Forum: B16M (https://www.kincony.com/forum/forumdisplay.php?fid=61)
+--- Thread: BM16 Problems (/showthread.php?tid=7887)
BM16 Problems - PWJ - 04-01-2025
First of im a newbie so please dont be hard on me. I purchased a B16M with Tuya it arrived yesterday. It came with no instructions but it seemed quite straight forward to connect up. Two terminals marked 12v I powered it up opened the Tuya app and hey presto it found it and installed it.
Once installed all the inputs and outputs were greyed out and no matter what I did. So I started hunting for instructions. Found the forum but couldnt post (but thats another story) found the ESP32 YAML File for home assistant installed that via ESPHome from my home assistant. That worked too but I was still unable to control the relays from HA even though the buttons moved on my HA nothing was happening on the board.
Now when I try to connect via usb the unit connects then disconnect connects then disconnect as if its drawing too much current and dropping out.
Ive since spoken via we chat and discovered there are some more 12v inputs (I suspect these drive the relays) connected these up but now I am just unable to connect to the unit.
Unfortunately Im at work now so unable to try any suggestions until this evening when I get home, but I would be grateful for any help that might point me in the right direction please. Ideally I need to get this back on Tuya.
Thanks Peter
RE: BM16 Problems - admin - 04-01-2025
new controller need download KCS v3 firmware via USB-C cable firstly.
RE: BM16 Problems - PWJ - 04-04-2025
Thanks I have installed the firmware and it seems to be behaving as expected now.
However, it only seems to activate the first 8 outputs in Tuya, its not important to me as i only purchased it for project that needed one Tuya input that I could control over ethernet, all the rest is surplus to requirements.
That said, I can see how this board could be useful with my Home assistant I do have varios esp32 boards scattered around the house doing lots of different things but I can see how a few of these units could replace some of these I just need to have a think about what they would improve.
When I get a minute I shall take a look at all the other KinCony boards available too
A great bit of kit, well done HiFiCat 谢谢
