KCSv3 ADC threshold does nothing with Home Assistant MQTT - Printable Version
+-- Forum: "KCS" v3 firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=74)
+--- Forum: "KCS" v3 firmware (https://www.kincony.com/forum/forumdisplay.php?fid=75)
+--- Thread: KCSv3 ADC threshold does nothing with Home Assistant MQTT (/showthread.php?tid=7967)
KCSv3 ADC threshold does nothing with Home Assistant MQTT - riri0 - 04-20-2025
Hi. Does the ADC threshold not apply to Home Assistant MQTT? For testing, my CH1 is around 1430 to 1450, value does not go above 1450. I put 100 so it should update in MQTT the value when it go above 1500 correct? But in Home Assistant MQTT the value still update every 2 second between 1430 to 1450.
The drop in the graph is when I try reboot the board to see if threshold apply after reboot. Still same.
RE: KCSv3 ADC threshold does nothing with Home Assistant MQTT - admin - 04-20-2025
you can replace "100" with "10". have a testing.
RE: KCSv3 ADC threshold does nothing with Home Assistant MQTT - riri0 - 04-20-2025
Still same update every 1-2 second
after saved setting, do you have re power on of your board?
