Does the KC868-A6 V1.4 board provide a 5V output for DS18B20 sensors? - Printable Version
+--- Thread: Does the KC868-A6 V1.4 board provide a 5V output for DS18B20 sensors? (/showthread.php?tid=8030)
Does the KC868-A6 V1.4 board provide a 5V output for DS18B20 sensors? - GetBK - 04-29-2025
Hi everyone,
I'm using the Kincony KC868-A6 V1.4 board and planning to connect several DS18B20 temperature sensors. I know these sensors can work with 3.3V, but they tend to be more stable with a 5V power supply—especially when using longer cables.
Does this board provide a dedicated 5V output pin that I can use to power the DS18B20 sensors? If so, where exactly can I find it on the board?
Any help or insights would be greatly appreciated!
Thanks in advance!
RE: Does the KC868-A6 V1.4 board provide a 5V output for DS18B20 sensors? - admin - 04-29-2025
we don't recommended get 5v power from PCB, because if the load is heavy, will let the board not stable. i don't know how many ds18b20 sensors you want to use. how long cable you want to use. if you have many sensor need connected, you can use a extend 5v power supply and good quality cable is better.
