Serial Monitoring - Printable Version
+-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=72)
+--- Forum: T16M (https://www.kincony.com/forum/forumdisplay.php?fid=73)
+--- Thread: Serial Monitoring (/showthread.php?tid=8032)
Serial Monitoring - joe.sfeir@gmail.com - 04-30-2025
Hi,
I am using Serial.begin() and Serial.println() but I see nothing in my Serial Monitor (Platformio). What could the problem be?
I am using 115200 as monitoring speed (configured in platformio.ini) and my Serial monitor is configured with the same rate.
I am using the demo code below:
* This program reads 16 input states from a PCF8575 I/O expander and
* controls a corresponding 16-channel relay module. When an input pin
* is LOW, the corresponding relay is turned ON (LOW means ON for the relay).
* When the input pin is HIGH, the corresponding relay is turned OFF.
* Pin Definitions:
* - SDA: GPIO 11
* - SCL: GPIO 12
* - Input I2C Address: 0x24
* - Relay I2C Address: 0x25
#include <Wire.h>        // I2C communication
#include <PCF8575.h>     // Library to control the PCF8575 I/O expander
// Define I2C pins
#define SDA 11           // SDA pin
#define SCL 12           // SCL pin
// I2C addresses
#define INPUT_I2C_ADDRESS 0x24   // I2C address for the input PCF8575 module
#define RELAY_I2C_ADDRESS 0x25   // I2C address for the relay PCF8575 module
PCF8575 pcf8575_IN(INPUT_I2C_ADDRESS);    // Create an object for the input PCF8575
PCF8575 pcf8575_RL(RELAY_I2C_ADDRESS);    // Create an object for the relay PCF8575
  Wire.begin(SDA, SCL);
  // Initialize input and relay modules
  pcf8575_IN.begin();
  pcf8575_RL.begin();
  // Turn off all relays at the start
    pcf8575_RL.write(i, LOW);  // Assuming relays are LOW when OFF, setting all relays to OFF initially
  Serial.println("System started: Input state controlling 16 relays");
  uint16_t inputState = 0;
  // Read the state of 16 inputs
    if (pcf8575_IN.read(i)) {
      inputState |= (1 << i);  // If input is HIGH, set the corresponding bit
    } else {
      inputState &= ~(1 << i); // Otherwise, clear the corresponding bit
  Serial.println("Test Point...");
  // Control the relays based on the input state
    if (inputState & (1 << i)) {
      pcf8575_RL.write(i, HIGH);  // If input is HIGH, turn the relay OFF
    } else {
      pcf8575_RL.write(i, LOW);   // If input is LOW, turn the relay ON
  // Delay for 500 milliseconds
  delay(500);
Thanks
