ESPHome yaml for DS18B20 and ADC 1 ~ 4 - Printable Version
+--- Forum: KC868-A4 (https://www.kincony.com/forum/forumdisplay.php?fid=21)
+--- Thread: ESPHome yaml for DS18B20 and ADC 1 ~ 4 (/showthread.php?tid=8060)
ESPHome yaml for DS18B20 and ADC 1 ~ 4 - call7612 - 05-08-2025
Could you let me get a sample ESPHome yaml file to obtain sensor data from DS18B20 and ADC 1 ~ 4?
My board is KC868-A4 Rev. is 1.2.4
RE: ESPHome yaml for DS18B20 and ADC 1 ~ 4 - admin - 05-08-2025
you can check at here: https://www.kincony.com/forum/forumdisplay.php?fid=54
RE: ESPHome yaml for DS18B20 and ADC 1 ~ 4 - call7612 - 05-12-2025
My question was solved. And, it is working well.
I hope to share my yaml file for other people
friendly_name: KC868A4
esp32:
board: esp32dev
framework:
type: arduino
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
- platform: esphome
password: "xxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
ssid: "XXXXXXXXXXXXXXXXXX"
password: "XXXXXXXXXXXXXXXX"
ap:
ssid: "XXXXXXXXXXXXX"
password: "XXXXXXXXXX"
captive_portal:
web_server:
port: 80
one_wire:
pin: GPIO13
remote_receiver:
number: 23
inverted: True
dump: nec
tolerance: 25%
filter: 50us
idle: 10ms
buffer_size: 2kb
remote_transmitter:
number: 22
carrier_duty_percent: 50%
pin: 2
inverted: false
pin: 15
inverted: false
pin: 5
inverted: false
pin: 4
inverted: false
- platform: template
turn_on_action:
- remote_transmitter.transmit_nec:
address: 0x719E
command: 0xFF00
command_repeats: 1
repeat:
times: 1
wait_time: 50ms
turn_off_action:
address: 0x719E
command: 0xFF00
command_repeats: 1
repeat:
times: 1
wait_time: 50ms
number: 36
number: 39
number: 27
number: 14
- platform: adc
pin: 32 # or 34
unit_of_measurement: "%"
update_interval: 5s
attenuation: 12db
# 0 ~ 4096
# filters:
# - lambda:
# if (x >= 3.11) {
# return x * 1.60256;
# } else if (x <= 0.15) {
# return 0;
# } else {
# return x * 1.51;
filters:
- lambda:
if (x >= 3.11) {
return x * 30.83751;
return 0;
} else {
return x * 29.24;
- platform: adc
pin: 33 # or 35
unit_of_measurement: "°C"
update_interval: 5s
attenuation: 12db
filters:
# - multiply: 1.51515
# Sensor 0~5V > 0~50'C
- lambda:
if (x >= 3.11) {
return x * 15.41876;
return 0;
} else {
return x * 14.62;
- platform: dallas_temp
address: 0x7c0000003497e528
update_interval: 10s
RE: ESPHome yaml for DS18B20 and ADC 1 ~ 4 - admin - 05-12-2025
thanks share your code.
