Does KCS v3 firmware for KC868-H16S3 support a 'delay' parameter in MQTT SET commands - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=60) +--- Forum: B16 (https://www.kincony.com/forum/forumdisplay.php?fid=70) +--- Thread: Does KCS v3 firmware for KC868-H16S3 support a 'delay' parameter in MQTT SET commands (/showthread.php?tid=8167) |
Does KCS v3 firmware for KC868-H16S3 support a 'delay' parameter in MQTT SET commands - itzek - 06-09-2025 Hello admin I am using a B16 smart relay controller with your KCS v3 firmware. I am integrating it with Home Assistant to control a Somfy WT roller shutter. For this application, I need to send an MQTT command to activate a relay for a specific duration (e.g., "turn on output1 for 3 seconds, then turn it off automatically"). I've reviewed the KCS v3 MQTT protocol document (specifically, section 1 about setting ON/OFF of a digital output channel). It shows how to turn relays ON or OFF: Code: {"outputX":{"value":true}}Code: {"outputX":{"value":false}}Code: {"delay": milliseconds}For example, would a command like this work to turn on Code: output1Code: {"output1":{"value":true}},{"delay":3000}Thank you for your assistance. RE: Does KCS v3 firmware for KC868-H16S3 support a 'delay' parameter in MQTT SET commands - admin - 06-09-2025 KCS mqtt protocol not support delay time. you can set the auto off time in KCS webpage -- OUTPUT, set the OUTPUT work as a "delay" mode. so that every time, when relay is ON, will auto off after x seconds. |
