rs485 SHT - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=62) +--- Forum: F16 (https://www.kincony.com/forum/forumdisplay.php?fid=63) +--- Thread: rs485 SHT (/showthread.php?tid=8179) |
rs485 SHT - Read.0h1 - 06-11-2025 I apologize for my lack of knowledge here but I am trying to set up an SHT temperature and humidity sensor (purchased through your website) to my F16 board. I found YAML in a different thread and copied it and changed the pin numbers to match my board. I am using ESPhome through Homeassistant. The YAML pertaining to the temperature humidity sensor is as follows: uart: - id: uart_modbus baud_rate: 9600 tx_pin: 16 rx_pin: 17 # Config Modbus modbus: uart_id: uart_modbus id: modbus1 modbus_controller: - id: modbus_sensor address: 0x01 # device address modbus_id: modbus1 sensor: - platform: modbus_controller modbus_controller_id: modbus_sensor name: "RS485 Temperature Sensor" id: temperature_sensor address: 0x0000 register_type: holding value_type: U_WORD unit_of_measurement: "°C" accuracy_decimals: 1 filters: - lambda: if (x < 10000) return x * 0.1; else return -1 * (x - 10000) * 0.1; - platform: modbus_controller modbus_controller_id: modbus_sensor name: "RS485 Humidity Sensor" id: humidity_sensor address: 0x0001 register_type: holding value_type: U_WORD unit_of_measurement: "%" accuracy_decimals: 1 filters: - multiply: 0.1 The sensors read as unavailalbe in homeassistant. I have a feeling that the issue may be in the address of the specific sensors, but I have no idea since I have never used the RS485 pins before. RE: rs485 SHT - admin - 06-12-2025 take a photo of your sensor. this is RS485+SHT30 sensor. if you only use SHT30 sensor, you should connect with i2c bus interface. RE: rs485 SHT - Read.0h1 - 06-12-2025 It’s the one from your website. It has rs485 A+B pins https://shop.kincony.com/products/rs485-temperature-and-humidity-sensor-modbus-rtu-use-by-sht30 RE: rs485 SHT - admin - 06-12-2025 you can use PC softare to test sensor first. make sure you have set the correct baud rate and rs485 address. RE: rs485 SHT - Read.0h1 - 06-13-2025 Is there recommended software? Also will I need a usb to rs485 adapter? RE: rs485 SHT - admin - 06-15-2025 yes, use usb-rs485 adapter to debug firstly is better. |
