KC868-A16 + 2 × R4DCB08 – CRC errors - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: KC868-A16 + 2 × R4DCB08 – CRC errors (/showthread.php?tid=8186) |
KC868-A16 + 2 × R4DCB08 – CRC errors - Akash24 - 06-13-2025 Hi KinCony team, Hardware • KC868-A16 (ESP32, ESPHome 2025.2.2, UART TX GPIO13 / RX GPIO16, 9600 baud, 8-N-1) • Two R4DCB08 temperature-collector boards, each with 4-8 × DS18B20 probes • 24 V DC power supply feeding both collectors • RS-485 cabling: shielded twisted pair Address & jumpers • Board 1 → Modbus ID 0x01, TERM OFF, BIAS OFF • Board 2 → Modbus ID 0x02, TERM ON (far end), BIAS OFF • KC868 terminator jumper → ON when only board #1 is present, OFF when both boards are in the chain Wiring topology KC868 A/B/GND → short stub to board #1 → 3 m cable → board #2 (terminator) (I originally had both collectors fanned out from a terminal block; I have now rewired them in strict daisy-chain as shown in the attachment.) Symptoms • With only board #1 on the line everything is stable – ESPHome reads register 0x0000 and publishes 23.8 °C. • As soon as I plug in board #2 I get continuous csharp CopyEdit Code: [W][modbus:125]: Modbus CRC Check failed!• Swapping A/B on both collectors made no difference. • If I change board #2’s address to 0x01, unplug board #1, it answers correctly, so the hardware itself works. What I’ve tried
Are there any known issues with two R4DCB08 units on the same KC868-A16 RS-485 bus? Can you suggest further tests (e.g. different termination/bias settings, oscilloscope waveforms to capture) or firmware settings that typically resolve “CRC Check failed” when the wiring looks correct? Log snippet and wiring photo are attached. Thanks in advance for any pointers! RE: KC868-A16 + 2 × R4DCB08 – CRC errors - admin - 06-15-2025 sorry, i don't have this type of sensor. i thnk,, you can test one A16 board with one sensor firstly. when work well, connect with second sensor. |
