B8 ESP32-S3 IO pins define - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=60) +--- Forum: B8 (https://www.kincony.com/forum/forumdisplay.php?fid=84) +--- Thread: B8 ESP32-S3 IO pins define (/showthread.php?tid=8225) |
B8 ESP32-S3 IO pins define - admin - 06-23-2025 IIC Bus: SDA:GPIO8 SCL:GPIO18 PCF8575: i2c address:0x22 PCF8575->P0 (digital input-1) PCF8575->P1 (digital input-2) PCF8575->P2 (digital input-3) PCF8575->P3 (digital input-4) PCF8575->P4 (digital input-5) PCF8575->P5 (digital input-6) PCF8575->P6 (digital input-7) PCF8575->P7 (digital input-8) PCF8575->P8 (relay1) PCF8575->P9 (relay2) PCF8575->P10 (relay3) PCF8575->P11 (relay4) PCF8575->P12 (relay5) PCF8575->P13 (relay6) PCF8575->P14 (relay7) PCF8575->P15 (relay8) 24C02 EPROM i2c address: 0x50 DS3231 RTC i2c address: 0x68 SSD1306 display: i2c address:0x3c ADS1115 (4CH ADC): i2c address:0x48 Analog input (A1: DC 0-5v) Analog input (A2: DC 0-5v) Analog input (A3: DC 4-20mA) Analog input (A4: DC 4-20mA) ----------------- 1-wire GPIOs (with pull-up resistance on PCB): 1-wire-1:GPIO47 1-wire-2:GPIO48 1-wire-3:GPIO7 1-wire-4:GPIO40 ----------------- free GPIOs (without pull-up resistance on PCB): GPIO13 GPIO14 GPIO21 ----------------- Ethernet (W5500) I/O define: clk_pin: GPIO1 mosi_pin: GPIO2 miso_pin: GPIO41 cs_pin: GPIO42 interrupt_pin: GPIO43 reset_pin: GPIO44 -------------------- RS485: RXD:GPIO38 TXD:GPIO39 Tuya module: RXD:GPIO17 TXD:GPIO16 Tuya network button: Tuya module's P28 Tuya network LED: Tuya module's P16 -------------------- SD Card: SPI-MOSI:GPIO10 SPI-SCK:GPIO11 SPI-MISO:GPIO12 SPI-CS:GPIO9 SPI-CD:GPIO5 |
