Modifying analog Inputs - Printable Version
+--- Forum: KC868-AIO (https://www.kincony.com/forum/forumdisplay.php?fid=46)
+--- Thread: Modifying analog Inputs (/showthread.php?tid=8271)
Modifying analog Inputs - danmolna - 06-26-2025
Hi!
I need 12pcs  0-5V analog inputs for a project and 16 DO.
ESPHome. Home Assistant.
As i see thist product is the most suitable from your catalogue.
But it has 8 0-5V and 8 4-20mA AI-s.
Is it possible to modify the 4-20mA inputs to 0-5V inputs by changing the resistances there to simmilar values like at the 0-5V inputs?
Thanks!!
Daniel
RE: Modifying analog Inputs - admin - 06-27-2025
sure, it's ok for change resistances as the 0-5v input channel circuit. every channel replace with two resistances .
RE: Modifying analog Inputs - danmolna - 08-06-2025
(06-27-2025, 12:03 AM)admin Wrote: sure, it's ok for change resistances as the 0-5v input channel circuit. every channel replace with two resistances .
Thanks! Good news!
Do You plan to release new version this product? Like A8-v3?
Thanks!
RE: Modifying analog Inputs - admin - 08-06-2025
yes, new version is under designing.
RE: Modifying analog Inputs - danmolna - 08-07-2025
(08-06-2025, 11:59 PM)admin Wrote: yes, new version is under designing.
Good news.  My other devices are the newer so if possible i wouldnt mix them.
I can wait few months. Do you have a target date for production?
Thanks!
Daniel
RE: Modifying analog Inputs - admin - 08-07-2025
first version, maybe after 1-2 month.
RE: Modifying analog Inputs - danmolna - 10-20-2025
(08-07-2025, 09:26 PM)admin Wrote: first version, maybe after 1-2 month.
Hi! Do you have maybe any news about the update status? Thank You! Daniel Smile
RE: Modifying analog Inputs - admin - 10-20-2025
new version is AIO Hybrid , it already released: https://www.kincony.com/esp32s3-all-in-one-smart-controller-aio-hybrid.html
RE: Modifying analog Inputs - danmolna - 10-21-2025
(10-20-2025, 11:34 PM)admin Wrote: new version is AIO Hybrid , it already released: https://www.kincony.com/esp32s3-all-in-one-smart-controller-aio-hybrid.html
Thanks for fast reply!
I see but it has less analog inputs.
I need the device to a complex heating room wirh many heatpumps and gas boilers.
I have there 12 analog themperature sensors.
Do you have better idea? Or simple buy the old version and modify the inputs as discussed before?
Thaks!
Daniel
RE: Modifying analog Inputs - admin - 10-21-2025
if you want use by 12 temperature sensors, you can check TA board, here is details: https://www.kincony.com/esp32-smart-tiny-alarm-system.html
