KC868 KCSv2.2.13 MQTT Update Issue - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: KC868 KCSv2.2.13 MQTT Update Issue (/showthread.php?tid=8273) |
KC868 KCSv2.2.13 MQTT Update Issue - paulbalinnel - 06-27-2025 Dear Kincony I use KC868-A8 with KCS v2.2.13[img]/local/images/tank0.png[/img] MQTT is connected correctly The sensor is configured for ADC1, via MQTT entity State topic* KC868_A8/2CBCBB658D44/STATE Value template {{ value_json.adc1.value }} Ground Feeder Tank Level 29 minutes ago (the sensor does not update) 1,171 V setting adc1 channel name: channel 1 unit: v Custom value1 ( value when adc/dac is 0 ): 0 Custom value2 ( value when adc/dac is max range ): 5 Threshold ( Send mqtt when the change of sampling value is greater than it ): 1 if I switch any output, the MQTT message does come, but no MQTT message when the ADC value changes RE: KC868 KCSv2.2.13 MQTT Update Issue - admin - 06-28-2025 what voltage input for test? 1.17V? RE: KC868 KCSv2.2.13 MQTT Update Issue - paulbalinnel - 08-17-2025 hello yes I have a voltage from 0-5V on the analogue sensor It was working well until this morning, the mqtt does not update on adc values, only if I switch the digital output, any then the new value of adc is sent Pls help!!! RE: KC868 KCSv2.2.13 MQTT Update Issue - admin - 08-17-2025 click the "gear" , set the "threshold" value for sensor, such as 1 , so that when data changed will auto feedback to mqtt. RE: KC868 KCSv2.2.13 MQTT Update Issue - paulbalinnel - 08-18-2025 I have done this, and it does not report on MQTT RE: KC868 KCSv2.2.13 MQTT Update Issue - admin - 08-18-2025 you can try set custom value1=0 custom value2=5 threshold=0.1 for a testing. RE: KC868 KCSv2.2.13 MQTT Update Issue - paulbalinnel - 08-19-2025 I did try this setting, no mqtt update, only update is when I switch Output on or off RE: KC868 KCSv2.2.13 MQTT Update Issue - admin - 08-19-2025 can you use newest KCS v2.2.14 firmware for a testing? erase all esp32 data, download newest firmware. RE: KC868 KCSv2.2.13 MQTT Update Issue - paulbalinnel - 08-25-2025 please I need your help, i have ereased, i have set factory reset, i have used latest firmware Board Model KC868_A8 Software Version v2.2.14 thre mqtt does not update on adc value changes ** I have used automation in Home Assistant to toggle output 8 on and off every 1 minute. this does update the the state on MQTT. a temporary fix. RE: KC868 KCSv2.2.13 MQTT Update Issue - admin - 08-27-2025 take a photo of your PCB board. |
