MQTT Auto discovery problem - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16v3 (https://www.kincony.com/forum/forumdisplay.php?fid=68) +--- Thread: MQTT Auto discovery problem (/showthread.php?tid=8275) |
MQTT Auto discovery problem - makaveledj - 06-27-2025 Hello everyone, I am using board A16v3 with KCS v3.9.4 firmware. I am trying to connect it with Home Assistant through ''MQTT (For Home Assistant)'' with auto discovery option set to ON, but unfortunately it cant connect to HA. I have watched kincony youtube videos and I am doing exactly the same, but with no success. I have tried to connect with just the MQTT option and it connects just fine, but I would like to use theĀ ''MQTT (For Home Assistant)'' with auto discovery option. Have you came across such problem? Any help will be appreciated. RE: MQTT Auto discovery problem - admin - 06-28-2025 take a photo of your setting screen. RE: MQTT Auto discovery problem - makaveledj - 06-28-2025 RE: MQTT Auto discovery problem - admin - 06-28-2025 sorry, i can't see any images. RE: MQTT Auto discovery problem - makaveledj - 06-30-2025 RE: MQTT Auto discovery problem - admin - 06-30-2025 because you have not input mqtt port: 1883, that is grey color, NOT enter. RE: MQTT Auto discovery problem - makaveledj - 06-30-2025 Thank you for your quick support! I works perfectly now! |
