KC868 server16 and i2C - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-Server Raspberry Pi4 local server (https://www.kincony.com/forum/forumdisplay.php?fid=17) +--- Thread: KC868 server16 and i2C (/showthread.php?tid=8276) |
KC868 server16 and i2C - fdcemb5 - 06-28-2025 I am trying to integrate the KC868 server 16 to add I2C hardware devices. I have done step 2 2. enable i2c for home assistant. Add files to enable I2C In the root of the hassos-boot partition, add a new folder called CONFIG. In the CONFIG folder, add another new folder called modules. Inside the modules folder add a text file called rpi-i2c.conf with the following content: i2c-dev In the root of the hassos-boot partition, edit the file called config.txt add two lines to it: dtparam=i2c_vc=on dtparam=i2c_arm=on but i2c devices are not showing. See attached screenshot RE: KC868 server16 and i2C - admin - 06-28-2025 take a photo of your config.text and your folder. RE: KC868 server16 and i2C - fdcemb5 - 06-29-2025 Attached are various screenshots Note that after inserting back the SD Card into the server16, if you put it back again to computer, the CONFIG folder disappears RE: KC868 server16 and i2C - admin - 06-29-2025 "Note that after inserting back the SD Card into the server16, if you put it back again to computer, the CONFIG folder disappears" this is issue. make sure you have wrote the file, maybe you you write the file again or change a new SD card. |
