Kc868-A16 - Printable Version
+--- Thread: Kc868-A16 (/showthread.php?tid=8293)
Kc868-A16 - fdcemb5 - 07-03-2025
Trying to integrate KC868-A16 with HA, I am getting an error after flashing the yaml file. See screenshot and yaml file attached
RE: Kc868-A16 - admin - 07-04-2025
just use by this yaml file: https://www.kincony.com/forum/showthread.php?tid=1628
RE: Kc868-A16 - fdcemb5 - 07-04-2025
(07-04-2025, 12:45 AM)admin Wrote: just use by this yaml file: https://www.kincony.com/forum/showthread.php?tid=1628
Does it mean I should not change the IP address? 192.168.1.199? my IP address is 192.168.1.100
no, that already commented, you can delete the static ip setting, just use by DHCP.
RE: Kc868-A16 - fdcemb5 - 11-27-2025
A16 does not retain State, when power goes off, it returns to Off State even if it is On state before pwoer goes off.
I used ESPhome to flash A16
RE: Kc868-A16 - admin - 11-27-2025
there is "restore_mode" option for ESPHome.
RESTORE_DEFAULT_OFF - Attempt to restore state and default to OFF if not possible to restore.
here is detail: https://esphome.io/components/switch/
RE: Kc868-A16 - fdcemb5 - 11-28-2025
(11-27-2025, 10:30 AM)admin Wrote: there is "restore_mode" option for ESPHome.
here is the detail: https://esphome.io/components/switch/
After adding the above lines in the YAML file, the board cannot flash, always displaying an error.
RE: Kc868-A16 - admin - 11-28-2025
you can try to change option.
