KinCony AG Pro Wireless ALL IN ONE Controller - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-AG / AG Pro / AG8 / Z1 (https://www.kincony.com/forum/forumdisplay.php?fid=30) +--- Thread: KinCony AG Pro Wireless ALL IN ONE Controller (/showthread.php?tid=8303) |
KinCony AG Pro Wireless ALL IN ONE Controller - fdcemb5 - 07-05-2025 Where can I find the Esphome YAML file for the KinCony AG Pro Wireless ALL IN ONE Controller to install HA? I want to integrate KinCony AG Pro Wireless ALL IN ONE Controller with HA RE: KinCony AG Pro Wireless ALL IN ONE Controller - admin - 07-06-2025 1. about RF433M sender and receiver, IR sender and receiver, you can see the yaml of KC868-AG, just confirm the pin define. 2. if you want to use zigbee with home assistant, you need to download tasmota firmware firstly, so that can use zigbee2mqtt for home assistant. here is guide: https://www.kincony.com/forum/showthread.php?tid=3244 RE: KinCony AG Pro Wireless ALL IN ONE Controller - fdcemb5 - 07-10-2025 I have not been able to configure KinCony AG Pro Wireless ALL IN ONE Controller to work with HA. All the post pointed is generic. The ESP tool used in your demo is obslete, and differ from the latest version. Again, the YAML file KinCony AG Pro Wireless ALL IN ONE Controller is nowhere to be found other than the generic one. For Juinors like us, it takes weeks to solve problem because of the generic approach. I will appreciate direct solution to configure KinCony AG Pro Wireless ALL IN ONE Controller with HA. I am exhausted. RE: KinCony AG Pro Wireless ALL IN ONE Controller - admin - 07-10-2025 ok, we will save your suggestion. RE: KinCony AG Pro Wireless ALL IN ONE Controller - fdcemb5 - 07-12-2025 (07-10-2025, 11:01 AM)admin Wrote: ok, we will save your suggestion. Help me with straightforward yaml file to flash this module. I urgently need this to help me continue my configurations. RE: KinCony AG Pro Wireless ALL IN ONE Controller - fdcemb5 - 07-12-2025 The function I need is to integrate AG Pro with HA in such a way that I can operate ZigBee devices from both HA and Smartlife. I have successfully flashed Tasmota firmware, configured TCP Tx and RX, and set up MQTT. However, in MQTT, I could not figure out the parameters to put in the Topic and Full Topic. I need help to get this device working. See attached screenshots RE: KinCony AG Pro Wireless ALL IN ONE Controller - admin - 07-12-2025 https://youtu.be/On2m4MrCvDQ https://youtu.be/qulioLjFWXU RE: KinCony AG Pro Wireless ALL IN ONE Controller - fdcemb5 - 07-19-2025 Each time power grip is taken off, AG Pro Wireless ALL IN ONE Controller will stop working. On investigation, I found that TCPStart must be started each time power grip goes off. How can I configure TCPStart to automatically start on booting. RE: KinCony AG Pro Wireless ALL IN ONE Controller - fdcemb5 - 07-20-2025 Each time power grip is taken off, AG Pro Wireless ALL IN ONE Controller will stop working. On investigation, I found that TCPStart must be started each time power grip goes off. How can I configure TCPStart to automatically start on booting. |
