KC868-A16v3 more 1Wire Temp-Sensor per Pin - Printable Version
+--- Thread: KC868-A16v3 more 1Wire Temp-Sensor per Pin (/showthread.php?tid=8306)
KC868-A16v3 more 1Wire Temp-Sensor per Pin - CarMagician - 07-07-2025
I got the KC868-A16v3 Board today.
There are three dedicated pins for 1Wire Sensors:
1-wire (pull-up resistance on PCB):
1-wire1:GPIO47
1-wire2:GPIO48
1-wire3:GPIO38
Is there a way to connect more than one sensor per pin?
I combined two sensors and hooked them up to HT1, there is no communication with the sensors.
If I only connect one sensor I can read temperature.
I need more than 3 temperature sensors so I thought about connecting all of them together.
Had an other project with a normal ESP and there it was possible with 6 sensors on one pin.
I would group them together in pairs of 5 for my project.
Any hints?
Regard
CarMagician
RE: KC868-A16v3 more 1Wire Temp-Sensor per Pin - admin - 07-07-2025
if you use ESPHome , it support one gpio with multi sensors. But KCS v3 not spoort that, maybe in future we will update firmware for that.
RE: KC868-A16v3 more 1Wire Temp-Sensor per Pin - CarMagician - 07-08-2025
(07-07-2025, 10:48 PM)admin Wrote: if you use ESPHome , it support one gpio with multi sensors. But KCS v3 not spoort that, maybe in future we will update firmware for that.
I use ESPHome.
I took the YAML from here and commented the GPIOs out.
  #- platform: gpio
  #  name: "A16v3 IO47"
  #  pin:
  #    number: 47
  #    inverted: true
  #- platform: gpio
  #  name: "A16v3 IO48"
  #  pin:
  #    number: 48
  #    inverted: true
  #- platform: gpio
  #  name: "A16v3 IO38"
  #  pin:
  #    number: 38
  #    inverted: true
And I updated the YAML
one_wire:
    pin: 47
  - platform: dallas_temp
    update_interval: 10s
But it does not work. Any idea?
Regards
CarMagician
RE: KC868-A16v3 more 1Wire Temp-Sensor per Pin - admin - 07-08-2025
you need check the address scaned in esphome LOG, then fill the address. such as :
address: 0x1234567812345628
update_interval: 120s
(07-08-2025, 05:58 AM)admin Wrote: you need check the address scaned in esphome LOG, then fill the address. such as :
Will test! Thank you very much!
And the board can really handle 24V DC right?
I want to control 24V Fans for cooling.
(2000 Rpm / 24V / 2,4W)
Regards
CarMagician
sure, dc24v is ok for KC868-A16v3
