How to configure HTTP post for Webhook - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16S (https://www.kincony.com/forum/forumdisplay.php?fid=47) +--- Thread: How to configure HTTP post for Webhook (/showthread.php?tid=8308) |
How to configure HTTP post for Webhook - land88 - 07-08-2025 Hi, My KC868A16s is connected to internet with LAN port, WIFI off (LAN IP 192.168.1.200, mask 255.255.255.0, Gateway 192.168.1.1). It get the Board time to internet, no problem, so I think the KC is really connected to internet, it is not behind a firewall. In custom protocol, I create Custom1, with : "routeur = HTTP POST", "HEX : Empty", "Message :Empty" and "URL(Otional)= https://xxxx.synology.me/api/webhook/Temp_DC_BAT_G_21deg", this url is my webhook that is open on internet With a Pc connected to internet, in chrome this url turn on my webhook on my home assistant (boolean ON), but if I run the custom1 in IFFTT, I get "success" on KC but in reality Nothing appears to my home assistant. An other isue, when I run this custom protocol, I loose the connection to the board, so I must reboot the board to local access to the web interface ! I think I have an issue to configure this custom protocol. Can you help me ? Thanks. |
