B16 MQTT & HA 2025.7 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=60) +--- Forum: B16M (https://www.kincony.com/forum/forumdisplay.php?fid=61) +--- Thread: B16 MQTT & HA 2025.7 (/showthread.php?tid=8345) |
B16 MQTT & HA 2025.7 - paulbalinnel - 07-27-2025 Board Model B16 Software Version v3.9.4 HOME ASSISTANT Installed version 2025.6.3 Latest version 2025.7.3 If I upgrade HA to the latest versions, the first 2 analog inputs become unavailable I use MQTT (HA). All other entities are available. RE: B16 MQTT & HA 2025.7 - admin - 07-27-2025 do you use KCS v3 mqtt auto discovery function? RE: B16 MQTT & HA 2025.7 - paulbalinnel - 08-11-2025 Hello, yes I do, I updated HASS to 2025.8.0 same issue RE: B16 MQTT & HA 2025.7 - admin - 08-11-2025 i think you have not set the "threshold" value in KCS adc setting. you need to set it, such as "10". so that if analog value changed difference data will auto feedback mqtt message to home assistant. RE: B16 MQTT & HA 2025.7 - paulbalinnel - 08-17-2025 i used the mqtt, not mqtt(ha), and all working good now Thanks!! |
