KinCony T32M Tiny ESP32 Smart Controller released - Printable Version
+--- Thread: KinCony T32M Tiny ESP32 Smart Controller released (/showthread.php?tid=8357)
KinCony T32M Tiny ESP32 Smart Controller released - admin - 07-31-2025
KinCony T32M tiny ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 32 channel MOSFET output, 4 channel 1-wire GPIOs, 3 channel free GPIOs. T32M have RS485 port. You can write any code by Arduino IDE / Micro Python / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. T64M use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
[Image: T32M-1.jpg]
Model No. KinCony T32M
Description: KinCony 32 Channel Tiny ESP32-S3 Smart Controller – T32M
Power supply: 12-24V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C
Installation method: DIN RAIL
Outputs:
32CH MOSFET Outputs, every channel use MAX 4A driver IC
Inputs:
32CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
2 buttons: 1:ESP32 Reset 2:ESP32 Download
free GPIO: 3CH (connect with ESP32S3 pin directly)
2CH analog input DC0-5V (A1,A2) 2CH analog input 4-20mA (A3,A4)
[Image: T32M-2.jpg]
RE: KinCony T32M Tiny ESP32 Smart Controller released - denpayer - 10-28-2025
Hi. What pins can I use for connect two I2C LCD displays ?
RE: KinCony T32M Tiny ESP32 Smart Controller released - admin - 10-28-2025
sure,use free gpio, config by esphome.
RE: KinCony T32M Tiny ESP32 Smart Controller released - denpayer - 11-13-2025
Hi. Thank you.
What is minimum and maximum voltage for Digital Inputs ?
RE: KinCony T32M Tiny ESP32 Smart Controller released - admin - 11-14-2025
DC 0-24v for digital input ports.
