Power supply 12V with battery - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Power supply 12V with battery (/showthread.php?tid=839) |
Power supply 12V with battery - superG - 10-10-2021 Hello, For my setup; I want to use an AC/DC 12V with an integrated battery (Kincony used in combination of my alarm system and domotic modules) I was thinking to use the MeanWell DRC-40A but the voltage is slightly above 12V. Is the input tolerant to 13V (voltage of the battery in float mode). I have: - K868-32b - Switch terminal board 2.1 Edit: - Terminal board 2.1 is OK as it use the ST 78M05 linear circuit power which has a 35V Max absolute input - That also means the chip will dissipate more power to drop down to 5V ( 16% more) Thanks RE: Power supply 12V with battery - admin - 10-10-2021 no problem, H32B use "TPS54331" power IC. the delay is DC12V, if use for DC13V will no problem. |
