KinCony T64M Tiny ESP32 Smart Controller released - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KinCony T64M Tiny ESP32 Smart Controller released (/showthread.php?tid=8396) |
KinCony T64M Tiny ESP32 Smart Controller released - admin - 08-01-2025 KinCony T64M tiny ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 64 channel MOSFET output, 4 channel 1-wire GPIOs, 3 channel free GPIOs. T64M have RS485 port. You can write any code by Arduino IDE / Micro Python / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. T64M use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri. ![]() Model No. KinCony T64M Description: KinCony 64 Channel Tiny ESP32-S3 Smart Controller – T64M Power supply: 12-24V DC Processor: ESP32-S3-WROOM-1U (N16R8) Size: 200mm*83mm*56mm interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C Installation method: DIN RAIL Outputs: 64CH MOSFET Outputs, every channel use MAX 4A driver IC Inputs: 64CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable) 2 buttons: 1:ESP32 Reset 2:ESP32 Download 1-Wire GPIO: 4CH (with pull-up resistance on PCB) free GPIO: 3CH (connect with ESP32S3 pin directly) 2CH analog input DC0-5V (A1,A2) 2CH analog input 4-20mA (A3,A4)
RE: KinCony T64M Tiny ESP32 Smart Controller released - martin_p - 08-15-2025 Hello, I would ask about digital input. How fast scan rate will this product know? I will use with wall button. Regards RE: KinCony T64M Tiny ESP32 Smart Controller released - admin - 08-15-2025 digital input use by PCF8575 i2c chip. it's enough deal with wall switch button. |
