Server-Mini and RS485 - IO Module – KC868-HAv2 - Printable Version
+--- Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module (https://www.kincony.com/forum/forumdisplay.php?fid=53)
+--- Thread: Server-Mini and RS485 - IO Module – KC868-HAv2 (/showthread.php?tid=8447)
Server-Mini and RS485 - IO Module – KC868-HAv2 - Mijoo - 08-13-2025
Hello, friends.
Help: Connect RS485 I/O modules to the Raspberry Pi 4 Relay Board (Server Mini) + Home Assistant OS
Hardware
Goal
  1. Daisy-chain several KinCony RS485 I/O modules to the Server Mini’s onboard RS485.
  2. Control/monitor them from Home Assistant OS (HA Modbus if possible).
  3. Best-practice for addressing many modules (bulk provisioning) without connecting a laptop each time.
What I’ve found / tried so far
  • The board exposes RS485 via the Pi’s UART (I see pins marked GPIO14 = TX, GPIO15 = RX on documentation/pins).
  • On Home Assistant OS, I cannot just edit /boot/config.txt like on Raspberry Pi OS, so I’m not sure about the correct way to enable the UART for the onboard RS485 under HA OS.
  • I tried using generic HA Modbus config but I’m not 100% sure about the device path (e.g. /dev/ttyAMA0, /dev/ttyS0, or /dev/serial/by-id/...) and serial parameters (baud, parity, stop bits) for KinCony’s RS485 port on this board.
  • I previously attempted the old rpi_gpio integration for direct GPIO, but HA OS doesn’t include that — so I want to use RS485/Modbus properly instead.
RE: Server-Mini and RS485 - IO Module – KC868-HAv2 - admin - 08-13-2025
repied in another thread.
