Using a different OLED - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A6v3 (https://www.kincony.com/forum/forumdisplay.php?fid=69) +--- Thread: Using a different OLED (/showthread.php?tid=8450) |
Using a different OLED - 1damo1 - 08-14-2025 Good Evening, hoping someone has done this or knows what I need todo. I'm looking to add a larger screen to the A6v3. I'm looking to add this type of screen, im having an issue with selecting the appropriate pins on the board & assigning the appropriate pins in my arduino code. Thankyou in advance Damien RE: Using a different OLED - admin - 08-14-2025 now A6v3 OLED screen use by i2c bus. you can also find a i2c LCD, it's easy to use if config by esphome. |
