KinCony N60 ESP32-S3 AC LoRa Energy Meter released - Printable Version
+--- Thread: KinCony N60 ESP32-S3 AC LoRa Energy Meter released (/showthread.php?tid=8451)
KinCony N60 ESP32-S3 AC LoRa Energy Meter released - admin - 08-14-2025
We have designed 60 Channel ESP32 energy monitor board – N60 (ESP32 30 Channel CT Clamp Energy Monitor) for home automation project. It based on ESP32-S3-WROOM-1U (N16R8) wifi chip. The hardware have 60CH CT Clamp sensor INPUT ports + 6CH ZMPT101B voltage sensor + SD card + LoRa module + OLED display + free GPIOs. Ethernet+RS485+i2c extender 60CH high-accuracy energy meter ic-BL0910 with CT clamp. You can write any code by Arduino IDE / Micro Python / ESP-IDF development tool to ESP32-S3 module. We will supply Arduino demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant for smart home automation DIY. N60 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. N60 support connect to your own cloud server by MQTT.
[Image: N60-1.jpg]
Model No. KinCony N60
Description: KinCony 60 Channel AC Energy Meter – N60
Power supply: 12-24V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,LoRa,USB-C,i2c extender
Installation method: DIN RAIL
CT Clamp: 60 channel 2000:1 CT clamp "voltage" sensor
6 channel AC voltage: AC 0-380v
Button-DL: ESP32S3 download
Button-EN: ESP32S3 reset
Button-RST: RESET for ARM CPU
LED:
D5: power LED
D7: error LED
D6: running LED
Free GPIOs: GPIO15,GPIO16
[Image: N60-2.jpg]
[Image: N60-diagram.jpg]
what's mainly different between N60 and M30 energy meter board:
1. N60 use by KCS v3 using ESP32-S3 large memory CPU, M30 use by KCS v2 using ESP32 CPU.
2. N60 have flash chip save the total energy data when N60 power off.
3. N60 use SD card to save energy data as excel file for every one hour.
4. N60 have i2c extender, easy extend i2c temperature and humidity sensors.
5. N60 have 2 free GPIOs use for sensor or KinCony G1 4G module.
6. N60 support use by MAX 250A CT clamp sensor. M30 support MAX 120A CT clamp sensor.
7. N60 support LoRa for KinCony ALR or KC868-A6v3 LoRa board.
8. N60 added new coefficient correction settings page
9. N60 use new Modbus protocol for user to read and config all channel data.
10. N60 support IFTTT, automatic send command by voltage or current or some other IF condition.
