esphome 2026.01 the configuration of ethernet - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: esphome 2026.01 the configuration of ethernet (/showthread.php?tid=8468) |
esphome 2026.01 the configuration of ethernet - pap - 08-27-2025 Hi With esphome 2026.01 the configuration of ethernet: type: LAN8720 mdc_pin: GPIO23 mdio_pin: GPIO18 clk_mode: GPIO17_OUT phy_addr: 0 have to be changed to the new Version. ethernet: type: LAN8720 mdc_pin: GPIO23 mdio_pin: GPIO18 clk: pin: GPIO17 mode: CLK_EXT_IN or CLK_OUT phy_addr: 0 All Posts or Documentation i am able to find (e.g. https://www.kincony.com/kc868-a16-ethernet-home-assistant-esphome-configure.html) shows deprecated Version of configuration of ethernet. Can you help me please with the mode (CLK_EXT_IN or CLK_OUT) setting for the KC868-A16? Thanks a lot Best Regards from Austria Peter RE: esphome 2026.01 the configuration of ethernet - admin - 08-27-2025 tested with this code: Code: ethernet:RE: esphome 2026.01 the configuration of ethernet - pap - 08-27-2025 Thanks a lot, working solution. Best Regards from Austria Peter RE: esphome 2026.01 the configuration of ethernet - admin - 08-27-2025 good. |
