KinCony Raspberry Pi CM5 Linux Server released - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KinCony Raspberry Pi CM5 Linux Server released (/showthread.php?tid=8500) |
KinCony Raspberry Pi CM5 Linux Server released - admin - 09-07-2025 KinCony Pi5 is a Raspberry Pi CM5 server for smart home automation and industrial automation control. It can use for home assistant local server. It's a Linux computer, you can install software by yourself, such as Node red. The product default CM5 version is CM5004000. It without Bluetooth and wifi, RAM:4G Lite version. ![]() Model No. KinCony Pi5 Description: KinCony Automation Local Server – Pi5 Power supply: 12-24V DC Processor: Raspberry Pi Compute Module 5 Size: 139mm*83mm*56mm interfaces: Ethernet(RJ45)-LAN 1000Mbps IPv4/IPv6,USB-C Installation method: DIN RAIL 2 × USB 3 sockets microSD card socket for CM5 Lite modules M.2 M key PCIe socket 1 × full-size HDMI 2.0 connectors DIP SWITCH for jumpers
