1-wire GPIOs - Printable Version
+--- Forum: KC868-A8v3 (https://www.kincony.com/forum/forumdisplay.php?fid=78)
+--- Thread: 1-wire GPIOs (/showthread.php?tid=8554)
1-wire GPIOs - JuDie07 - 09-16-2025
KC868A8-V3 under ESPHome 2025.8.4
Question: Can the 1-wire GPIOs be connected to the (with pull-up resistance on PCB):
S1:GPIO40
S2:GPIO13
S3:GPIO48
S4:GPIO14
Can other sensors be connected that do not require a pull-up resistor?
For example one:
- platform: ledc
  pin: GPIO40
  inverted: false
RE: 1-wire GPIOs - admin - 09-16-2025
if you don't want pull-up resistor, you need to remove the pull-up resistor from PCB.
