Kincony A-16 Webserver with realtime updates using micropython - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: Kincony A-16 Webserver with realtime updates using micropython (/showthread.php?tid=8568) |
Kincony A-16 Webserver with realtime updates using micropython - nikhuge - 09-18-2025 https://github.com/charithmadhuranga/Micro-Python-Kincony-A16-Webserver/. check out the code in the github
RE: Kincony A-16 Webserver with realtime updates using micropython - orninten - 09-19-2025 One suggestion: you might want to add better error handling around I/O operations (e.g. file reads or network failures) so that unexpected issues don’t crash everything. Also, some unit tests for your handlers would help ensure robustness
