KC868-E16v2 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=62) +--- Forum: F16 (https://www.kincony.com/forum/forumdisplay.php?fid=63) +--- Thread: KC868-E16v2 (/showthread.php?tid=8572) |
KC868-E16v2 - mcdave - 09-21-2025 Dear Admin, I have T64m Power 12V PSU.... What is the problem if KC868-E16v2 COM TO NO reading 11.7v thats why my siren 12V not trigger, Do I need to seperate 12V PSU for t64M and KC868-E16v2.? RE: KC868-E16v2 - admin - 09-21-2025 take a photo how you wire, or write your diagram on paper. RE: KC868-E16v2 - mcdave - 09-22-2025 (09-21-2025, 11:34 PM)admin Wrote: take a photo how you wire, or write your diagram on paper. Hi Admin, I believe I've identified the issue. I am using a T64M power PSU DC Power Supply - DC12V 4.5A. This power supply also splits to supply the KC868-E16v2 DIN Rail Relay. This setup might explain why the COM & NO only voltage reading is 11.6V. Is it possible that this is due to my PSU only being 4.5A? Thanks, Dave RE: KC868-E16v2 - admin - 09-22-2025 maybe you have connect wrong pole, so i want to see your diagram how you wire, please take photo, so that can help you, i don't want to guess quesiton. |
