KC868-A16 - Printable Version
+--- Forum: "KCS" v2 firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40)
+--- Thread: KC868-A16 (/showthread.php?tid=8674)
KC868-A16 - eligijus - 10-24-2025
Hello, can you upload an example yaml file # DHT22 temperature-humidity sensor integration into home assistant
RE: KC868-A16 - admin - 10-24-2025
https://esphome.io/components/sensor/dht/
RE: KC868-A16 - eligijus - 10-25-2025
I Am using the kcs v2 firmware system
RE: KC868-A16 - admin - 10-25-2025
config the sensor with DHT22 with free GPIO.
[Image: sensor-webpage.png]
RE: KC868-A16 - eligijus - 10-26-2025
I Need the sensor configuration file for homeassistant.
RE: KC868-A16 - admin - 10-26-2025
if you use KCS v2 firmware, integrate to home assistant by MQTT.
here mqtt document include sensor message format: https://www.kincony.com/forum/showthread.php?tid=3105
RE: KC868-A16 - eligijus - 10-28-2025
I’m not a professional, I don’t understand how to write code correctly — could you upload an example?
I need an example of temperature and humidity.
RE: KC868-A16 - enochjason - 10-29-2025
(10-28-2025, 02:56 PM)eligijus Wrote: I’m not a professional, I don’t understand how to write code correctly — could you upload an example?
I also need full working Yaml code fo home Assistant. Dear Admin, could you kindly paste the full code here?
to discover 16 inputs, 16 outputs, sensors, and RF control.
Kindly help. I am using version2
Dear Admin, could you kindly paste the full code here for A16 device to be discovered in Home Assistant.
Kindly help. I am using version2. Thank you
RE: KC868-A16 - eligijus - 10-31-2025
  - name: "Sensor 1 Temperature"
    unique_id: a17-kcs-sensor-1-temperature
    icon: mdi:thermometer
    state_topic: "KC868_A16/90380CA43774/STATE"
    value_template: "{{ value_json.sensor1.temperature }}"
    unit_of_measurement: "°C"
    device_class: temperature
  - name: "Sensor 2 Temperature"
    unique_id: a17-kcs-sensor-2-temperature
    value_template: "{{ value_json.sensor2.temperature }}"
  - name: "Sensor 3 Temperature"
    unique_id: a17-kcs-sensor-3-temperature
    value_template: "{{ value_json.sensor3.temperature }}"
  - name: "kc868_humidity_1"
    unique_id: uniqueid__kc868_humidity_1
    icon: mdi:water-percent
    value_template: "{{ value_json.sensor1.humidity }}"
    unit_of_measurement: "%"
    device_class: humidity
  - name: "kc868_humidity_2"
    unique_id: uniqueid__kc868_humidity_2
    value_template: "{{ value_json.sensor2.humidity }}"
  - name: "kc868_humidity_3"
    unique_id: uniqueid__kc868_humidity_3
    value_template: "{{ value_json.sensor3.humidity }}"
this code worked
