kc868-server16 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-Server Raspberry Pi4 local server (https://www.kincony.com/forum/forumdisplay.php?fid=17) +--- Thread: kc868-server16 (/showthread.php?tid=8692) |
kc868-server16 - fdcemb5 - 11-01-2025 My server started behaving strangely yesterday, showing 'out of memory,' and a process was killed during the update of the ESPHome device. I have tried but could not resolve the issue. Any help will be appreciated. See picture RE: kc868-server16 - admin - 11-01-2025 do you use eMMC or SD card? RE: kc868-server16 - fdcemb5 - 11-04-2025 (11-01-2025, 11:33 PM)admin Wrote: do you use eMMC or SD card? I used SD card of 126gb RE: kc868-server16 - admin - 11-04-2025 maybe you can try to re install home assistant. RE: kc868-server16 - fdcemb5 - 11-10-2025 I have successfully reinstalled HA, but the 16-channel controller of Server16 is not maintaining state. When the server is turned off, it loses its state and goes entirely to the Off State on booting. What can be the response to this? |
