Esphome restart stand alone - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Esphome restart stand alone (/showthread.php?tid=8731) |
Esphome restart stand alone - wchpikus - 11-08-2025 Hello, I have 3x a16 added to HA, but when HA is not availble,i have restart from time to time. I added api, reboot_timeout 0, but not help. Now i see on debug no client connected, rebooting. Is it any sollution to fix restarts when a16 with esphome can working stand alone? Mayby connect a16 together? Then any a16 will be as serwer and client? I made light shaft and any reboot reset relays.. Need solution,please. Regards RE: Esphome restart stand alone - admin - 11-08-2025 do you integrate to home assistant by ESPHome? if YES, suggest you integrate by MQTT, so that HA is broken, KCS fimrware also work locally. RE: Esphome restart stand alone - wchpikus - 11-09-2025 Yes, a16s are integrated with HA. This reboot appear when ha is not availble. Mayby use one a16 to use GET http to ask for e.g. status of lan other a16? Is it reset "no client" watchgod? RE: Esphome restart stand alone - lulu01 - 11-09-2025 You can add 'reboot_timeout 0' in 'api:' which you did, but also in 'wifi:' and 'mqtt:' if you use this. You will have more luck in the ESPHome forum then here I think. https://community.home-assistant.io/c/esphome/ |
